fuelrails removal
Old Apr 16, 2004 | 07:05 PM
Evilfrog's Avatar
fuelrails removal
Its just the two bolts on top and on each side? Right?
Old Apr 16, 2004 | 07:12 PM
Eddie95Z28's Avatar
Right... 4 bolts and a pretty good amount of controlled pulling. The injectors can be a pain in convincing them to let go of the intake.
Old Apr 16, 2004 | 08:06 PM
z28poweredlt1's Avatar
actually its not that easy! you ogtta ahve the addapters to get the fuel lines off or you're gonna get stuck! a little bit of mobile 1 synthetic oil in the tip top of were the injector meets the intake, with a twist or two should free them up pretty easy, a little trick we use at the shop, and when you put them back on use white lithium greese and try and keep the bottum of the injector clean.
Old Apr 16, 2004 | 08:49 PM
Evilfrog's Avatar
Thanks eddie, wanted to make sure before i used force. Um...already got them the new injectors in, but the oil and grease sounds like a great idea. Kinda wish i read that before hand. Thanks guy.
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
