Fuel Return Line Questions??
Old Oct 14, 2007 | 11:46 AM
jammer94's Avatar
which is it? is it the smaller tube or the thicker one i would think it the one not going to the regulator but the one coming out the other end of the fuel rail....is it the skinnierplastic hose or is it the thicker one?thats all i needed to know.
also the plastic fuel line thats used on are cars is a ABS plastic material correct.
Old Oct 14, 2007 | 01:05 PM
mrmint69's Avatar
On my car the bigger one is the feed line and the smaller one the return to the tank. It has to be that way since you have more gas coming than going back.
Old Oct 14, 2007 | 02:00 PM
jammer94's Avatar
do you have an aftermarket fuel setup on you car or are you using the factory fuel lines?
Old Oct 14, 2007 | 02:48 PM
The fuel lines are nylon.
Old Oct 14, 2007 | 03:44 PM
jammer94's Avatar
thats great Rob but is the return the smaller of the 2 lines or the larger...
Old Oct 14, 2007 | 03:52 PM
blueformula350's Avatar
The return line is definitely smaller.
Old Oct 14, 2007 | 04:47 PM
You already had the answer, so I did not answer it again. 3/8" is the feed, 5/16" is the return.
Old Oct 14, 2007 | 10:28 PM
And the return line is the one that connects to the fuel pressure regulator. The feed goes into the back of the passenger side rail.
HectorM52
Jul 30, 2017 11:46 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
