Fuel Rail Covers/TCS?
Old Aug 20, 2003 | 09:58 AM
Green G0blin's Avatar
will fuel rail covers fit a car that is hooked up with traction control?
Old Aug 20, 2003 | 10:23 AM
BradZ28's Avatar
I asked this question about a month ago and did not get a response. Many people have remove traction control by getting a new throttle cable and tossing the TCS. I beleive that is what would need to be done.
Brad
Old Aug 20, 2003 | 10:44 AM
BitCypher's Avatar
From what I've heard, they will fit but you'll have to significantly modify the driver-side cover so that the TCS box fits through it. This usually fugs-up the whole reason most people put the covers on in the first place.
Old Aug 20, 2003 | 08:23 PM
kevmor99's Avatar
When I was installing the covers I found that the two alternator brackets wouldn't fit anymore (without notching the covers). Is it ok to run without those extra bracket supports (that go to the intake and also the the exhaust manifold bolt)?
Old Aug 20, 2003 | 08:48 PM
AsianSensation's Avatar
It's not that hard to notch the fuel rail cover for the altinator bracket.
See pic and ignore the burnt wire
ad356
Apr 16, 2015 05:38 PM
dfarr67
Apr 10, 2015 07:44 PM
4586
Feb 13, 2015 09:16 AM
birdblack
Dec 30, 2014 06:59 PM
2001CamaroGuy
Apr 5, 2006 10:56 PM
