fuel questions with cam
Old Sep 30, 2003 | 03:01 PM
93M29FOURMULA's Avatar
I plan on doing a cc 306 or a gm 847 cam on some P&P heads. My question is that I have a 93 and I was wondering if I need bigger injectors to do the swap? I live at high altitiude (5280ft-5800 ft) if that helps.
Old Sep 30, 2003 | 03:12 PM
flyinZ's Avatar
Depends if your gonna get bigger valves, run nitrous,etc...
Old Sep 30, 2003 | 03:17 PM
I plan on adding a fuel pump, the heads will have bigger valves (they are stg 2 heads), and I might run nitrous. I was wondering since I live at such high altitude that I could get away without getting injectors.
Old Sep 30, 2003 | 03:30 PM
flyinZ's Avatar
Personally, I would get bigger injectors..like 30#'s, and adjustable fuel pressure regulator..You should be fine.
Old Sep 30, 2003 | 05:36 PM
llafro's Avatar
Get the injectors. Why would you risk melting down an engine you just spent several thousand on because you don't want to spend $200 on a set of injectors?
BRAD
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
