Fuel Pump Voltage Questions
Old Jun 23, 2011 | 10:41 PM
DarkKnight's Avatar
Just 2 questions...
What does a fuel pump voltage booster do?
When is when needed?
Old Jun 23, 2011 | 11:36 PM
MikeGyver's Avatar
Re: Fuel Pump Voltage Questions
They increases voltage to the fuel pump, and therefore fuel flow.
Some switch to a higher voltage at a given TPS voltage of boost PSI, while others (such as the one I made https://www.camaroz28.com/forums/sho...d.php?t=810985) ramp voltage up linearly with boost.
They're used as a much simpler alternative to adding another pump when you're pump is maxed out.
Old Jun 23, 2011 | 11:39 PM
DarkKnight's Avatar
I see...so is it only needed for superchargers or turbos?
Old Jun 23, 2011 | 11:40 PM
MikeGyver's Avatar
No, any time your pump cannot deliver the fuel flow required, increase it's voltage and it pumps more fuel.
Old Jun 23, 2011 | 11:44 PM
DarkKnight's Avatar
I have a 383 stroker in a 94Z...it has a walbro 255 fuel pump in it. Would one be needed?
Old Jun 23, 2011 | 11:54 PM
MikeGyver's Avatar
Very unlikely. a walbro gss340 will support over 550hp
Old Jun 23, 2011 | 11:58 PM
DarkKnight's Avatar
Thanks for the info...
Awesome thread, by the way. Nice work.
RiverMutant96
Jan 30, 2015 09:21 AM
Gtpguy
Jan 26, 2015 04:50 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
ANDYZ28
Dec 29, 2014 09:13 PM
