fuel pump check valve
Old Mar 26, 2004 | 08:07 AM
30thannZ28's Avatar
where can I buy just the fuel pump check valve? my local chevy dealership does not sell those separate, and napa doesn't carry them.
Old Mar 26, 2004 | 08:13 AM
Not sure what you mean. There is a check ball, but it is internal to the pump.
Old Mar 26, 2004 | 08:18 AM
30thannZ28's Avatar
WOW! that was wierd. I was about to e-mail you shoebox, two seconds before I saw you replied to my thread. I'm referring to the tan colored "valve" looking thing that is inside the fuel tank assembly, but not actually inside the fuel pump housing itself. I hope that makes sense. Anyway, I was told by a reputable shop about a year ago that my "fuel pump check valve" was bad, along with my fuel pump. everything is out of the car right now. talk about a PITA!
Old Mar 26, 2004 | 08:51 AM
HBHRacing's Avatar
I bleive that you are talking about the float arm for the fuel level sending unit? I think?
They should have that at the dealer as a sending unit and some aftermarket companys as well.
Is that what you mean?
Old Mar 26, 2004 | 08:52 AM
30thannZ28's Avatar
no, it's not the float arm. It's an actual valve, but I don't know for sure if it is called the check valve or what. It is tan in color, and I think the float arms are all yellow in color. mine is.
Old Mar 26, 2004 | 09:22 AM
HBHRacing's Avatar
bad pic but best I could find on short notice.. can you point it out to us?
http://www.taekwondoplus.org/z28/walbro02.jpg
Old Mar 26, 2004 | 03:58 PM
30thannZ28's Avatar
far right of the screen, in the middle. the tan/sandy colored cylindrical short object.
Old Mar 27, 2004 | 05:29 AM
HBHRacing's Avatar
I belive that is just the port whre the return hose connects. if thats what you mean. excess gas is returned through there and back into the tank. if it;s leaking to the outside it should be replaced, if i;s leaking back into the tank i don;t see an issue unless it;s letting air inside or gas outside
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Jul 4, 2005 05:00 PM
