Fuel Problems. FPR/Pump or both?
Old Sep 25, 2006 | 04:31 PM
1FstFormulaV8's Avatar
I have narrowed my problem down to a fuel issue. I have measured with my fuel pressure gauge and came up with these numbers.
Vacuum line on:
Ignition on: 28 PSI.
Idle: 30-36 PSI. Cannot get an accurate reading. Gauge in rapid fluctuation.
Ignition off: 36 PSI. Sometimes it goes climb past 40.
WOT: 32 PSI.
Bleed down time 36 PSI - 0 PSI. 24 Minutes.
Vacuum line off. No fuel in vaccum line.
Igntion on: 30 PSI.
Idle: 26-40 PSI. Cannot get an accurate reading. Gauge in rapid fluctuation.
WOT: 36 PSI.
Few little notes.
When I am under hard acceleration there is a rapid fluctuation 20-40 PSI. After I have let off the throttle it drops down to 32 PSI. Not always.
Whenver I turned the vehicle off the fuel pressure sometimes climbs. I sometime hear the pump prime and sometimes it does not. The vehicle starts a lot faster when I put the throttle to the floor.
Am I looking at a FPR or a pump problem? Or a combination of both?
Old Sep 25, 2006 | 07:51 PM
Re: Fuel Problems. FPR/Pump or both?
Nothin'?
Old Sep 25, 2006 | 08:37 PM
OBE1 95Z28's Avatar
Fuel pressure should not be bouncing around while holding the throttle steady. Sounds more like a fuel pressure regulator to me. Is there any fuel in the vacuum line when you pull it off?
Old Sep 25, 2006 | 08:47 PM
Nah. That was the first thing I checked. I have been looking into a new regulator. The one from Holley looks promising. I would like to add a pressure guage on as well. Anyone know if the one from Accell will fit the Holley? And what kinda additional fittings do I need?
AtlasXVIII
Aug 2, 2015 10:29 AM
andrewcapps82
May 19, 2015 10:11 PM
ad356
Apr 16, 2015 05:38 PM
Cam's maro
Mar 24, 2015 08:09 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
