Fuel Pressure Rising - Key Off
Old Aug 21, 2006 | 09:16 PM
Deadpedal's Avatar
I've been having a lot of trouble starting my car, especially in the morning after sitting all night. It cranks and sometimes sputters, pops out the intake. Other times it starts ok but it still takes a bit more cranking then it should.
So tonight I was checking the fuel pressure and here are the results.
KOEO - 44 primes drops to 38
Running - 36 - 38 gauge needle flutters
Running w/ regulator disconected - 44-46 gauge needle flutters
So here's the problem. When I shut the car off the gauge started rising and within 20-30 secs it went up to 42 and held there. When I tried to relieve the pressure in the gauge, gas wouldn't stop pouring out of the tube, unless I let go of the button of course. It was coming out fast too, no little trickle.
I'm not sure what causes that, pump? regulator?
Is it normal for the gauge needle to bounce around a little while the car is running?
Old Aug 21, 2006 | 11:36 PM
EuroticCustoms's Avatar
Re: Fuel Pressure Rising - Key Off
have you changed the fuel filter?
Old Aug 21, 2006 | 11:46 PM
razor02097's Avatar
It is normal for the pressure to vary slightly with the engine running. When the car is off the fuel system should be pressurized for the next time you start the engine. That is why when you do fuel system work you always depressurize the system first. What Im trying to say is even when the car is off you will still have some pressure in the fuel system how much I don't really know.
Old Aug 22, 2006 | 12:05 AM
Deadpedal's Avatar
I changed the filter about 5k miles ago. I am going to put a new one in tomorrow.
razor02097: That is why when you do fuel system work you always depressurize the system first.
...but it won't depressurize. gas cap off, fuel pressure gauge connected to schrader valve...when I open the valve to relieve the fuel system pressure it just keeps pouring out.
I took the gauge completely off, tried about 20 mins later, same thing.
Old Aug 22, 2006 | 01:48 AM
1racerdude's Avatar
That's 'cause the "Tiger in the Tank" is making laps in the tank.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
Jul 4, 2005 05:00 PM
