Fuel Pressure / Injectors
Old Jan 12, 2011 | 11:33 AM
  #16
Re: Fuel Pressure / Injectors
The best log would be a cold start, warmup to closed loop (about 3 to 4 minutes), and a drive of several minutes, including low load and WOT, and at whatever conditions replicate the problem (if it happens under load), followed by a 15 second idle period before you shut it off.
Old Jan 17, 2011 | 01:01 AM
  #17
rangers458's Avatar
Well, I was totally off with this one.
Reset the valves today on the drivers side, and the car runs fine now.
I did have a slight tap, like a hung up lifter, however when I pulled the valve cover off, one of the rockers loosened to the point the push rod was not even attached.
What the hell would have caused that?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dfarr67
Apr 10, 2015 07:44 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
