fuel pressure drop off related too voltage
Old Aug 31, 2005 | 08:59 AM
simple's Avatar
what kind of fuel pressure drop off would one typically see when the voltage at the pump is down?
whats a good way too test voltage at the pump under WOT driving?
my fuel pressure is dropping off only under WOT and i believe it too be either a weak pump in general, low voltage too the pump causing pressure loss or another hole has developed in the convoluted tubing. (i've diagnosed everything else in the system)
its also taking forever (10-15sec) for it too build pressure on start up....even while the car is running
Old Aug 31, 2005 | 09:46 AM
turbo_Z's Avatar
Re: fuel pressure drop off related too voltage
Its my understanding weak pumps draw more current which is why it reads low.
Old Aug 31, 2005 | 09:52 AM
simple's Avatar
oh and the whole taking 10-15sec for the pressure too build up on start up just recently started happening after adding more fuel thru tuning
Old Aug 31, 2005 | 09:53 AM
simple's Avatar
Originally Posted by turbo_Z
Its my understanding weak pumps draw more voltage which is why it reads low.
draw more voltage?
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
