fuel line
Old Dec 15, 2008 | 06:27 PM
blackz151's Avatar
fuel line
How do i get the fuel lines to disconnet from the rails? Ive been trying for days. I have fuel like disconnet tools i got from discount auto and they are not working or i am not doing it right. Is there any tricks? or ? Realy starting to get to me lol
Old Dec 15, 2008 | 07:17 PM
Green96Z's Avatar
Slide the tool in, hold it in there tight. Push in on the fuel line, then pull out. If you don't push in first you can tug on it all day and it won't move.
Old Dec 15, 2008 | 07:51 PM
RamAir95TA's Avatar
Push the disconnect tool in until it bottoms out (make sure you're using the right side/size). Then push HARD until you hear it pop. It might take some effort but once it pops you should be able to pull it off no problem.
Old Dec 15, 2008 | 09:10 PM
blackz151's Avatar
I got the small one of but now I can't get the big one off for the life of me
Old Dec 15, 2008 | 10:00 PM
RamAir95TA's Avatar
The fuel lines are both the same size - you have two different lines?
Old Dec 15, 2008 | 10:18 PM
Green96Z's Avatar
The feed line is 3/8", return is 5/16".
http://shbox.com/1/fp_reg.jpg
Old Dec 15, 2008 | 10:27 PM
RamAir95TA's Avatar
How about it...hahah.
Old Dec 15, 2008 | 10:50 PM
blackz151's Avatar
yea i got the return line off
Old Dec 20, 2008 | 03:32 PM
RB97Z28's Avatar
I just removed and replaced my fuel lines about three months ago. Yep, the lines are a bear to get off(at least the 3/8 feed line was). I picked up my plastic disconnect tools from AutoZone. Struggled with the 3/8 feed line for a day and a half(well, it seemed that long!!!). I first thought I didn't have the right tools. Started with the 3/8 feed line because it's in front of the 5/16 return line and looked like it was eaiser to get to. Finally gave up on the 3/8 feed line and started on the 5/16 return line. It came right off with hardly any effort. Went back to the feed line and gave it a good hard tug and it finally came off. You just need to be persistent---It'll come off for you. Just know it'll be easier to get back on.
Old Dec 20, 2008 | 04:11 PM
Kevin Blown 95 TA's Avatar
the feed line is hard if its pressurized
so relieve the pressure at the schraeder valve first.
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
