fuel injectors too big?
Old Mar 12, 2009 | 03:10 PM
94formulacoup's Avatar
I recently put put my old setup back in the 94 trans am after blowing up the 396.Its a stock engine with ported heads and a gm 847 cam.58 mm throttle body,slp cold air intake,and ported intake.Im running comp cams pro magnum 1.6 rockers.It has long tube headers,no cat and straight through muffler.The car is a 6 speed with 4.11 rear gears.Im also running an electric water pump and a double roller timing chain.It no longer has egr or air pump.I also deleted the a/c.I had to reuse the injectors i ran with the 396 wich are 42 lb and even with a tune i seem to be burning through the gas and have a slight hesitation at low rpm.It pulls hard under full throttle and seems fine.Should i go back to 30 lb injectors?Also what kind of horse power guestamit with this setup?The 396 dynoed at 547 rwhp.Thanks guys.
Old Mar 12, 2009 | 03:25 PM
MikeGyver's Avatar
Do you know if the base pulse width dipping below the 'minimum pulse width' parameter in the tuning?
I'm running 60# mototrons on a stock motor with no idle problems (even before I adjusted the min pulse width).
Old Mar 12, 2009 | 04:11 PM
Stl94LT1's Avatar
With how much nitrous?
Old Mar 12, 2009 | 05:37 PM
not sure if its dipping below pulse width and the 396 had a 125 shot
Old Mar 12, 2009 | 07:40 PM
MikeGyver's Avatar
Did you de-screen the MAF?
Old Mar 12, 2009 | 11:32 PM
mrmint69's Avatar
You can run 42's on stock motor. You must have other problems going on besides injectors.
AdsoYo
May 2, 2018 03:21 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
