Fuel injectors not firing...why???
Old Sep 30, 2005 | 04:04 PM
Baseballstud's Avatar
has anybody else had this problem, i put a 96 lt1 in 71 camaro, everything is fine but my injectors are firing. W/ starting fluid bypassing the injectors it runs fine, but w/out starting fluid doesn't crank. Any suggestions would be helpful. Got power to the injectors. and I THINK all my grounds. Thanks in advance. Ryan
Old Sep 30, 2005 | 04:22 PM
Re: Fuel injectors not firing...why???
Have you checked for any codes in the PCM? If the PCM can not find the low resolution pulse from the Optispark, it shuts down the fuel system, including the pump and the injectors.
Old Sep 30, 2005 | 04:36 PM
VATS is usually a concern in a transplant. If you have not made arrangements (ie. fuel enable bypass module or having VATS programmed out) to get around it, the PCM will not enable the injectors.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
