Fuel Injectors
Old Feb 14, 2003 | 08:05 AM
4th-gen-formula's Avatar
Fuel Injectors
What is the best place (cheapest) to get 30 or 36 lb injectors
Old Feb 14, 2003 | 09:21 AM
rskrause's Avatar
Moderator
Racetronix at http://www.racetronix.com/ seems to have some good prices. They list 37lb injectors on their site for $38/injector.
Rich Krause
Old Feb 14, 2003 | 05:59 PM
nateh's Avatar
Summit Racing has a set of SVO 30 lb. injectors for $219.95.
http://store.summitracing.com/partdetail.asp?part=7202
Old Feb 14, 2003 | 06:05 PM
Draco's Avatar
Re: Fuel Injectors
You can get them cheap on eBay and some of the Mustang boards. I am assuming you don't mind used injectors
Old Feb 15, 2003 | 01:36 PM
Racetronix's Avatar
Post Re: Re: Fuel Injectors
Buying used injectors is a gamble unless you have someone flow-test them for you before putting them to use. You don't know how long they have been run and what condition they are in. Even a fairly new injector left sitting can seize up if not oiled and stored in a dry location.
Old Feb 15, 2003 | 01:53 PM
96ltz's Avatar
Re: Re: Re: Fuel Injectors
Do you clean/flow test injectors?
Old Feb 15, 2003 | 02:12 PM
Racetronix's Avatar
Post Used Fuel Injectors
Yes we do clean and test injectors here.
Cleaning an injector can not fix a weak spring, rusted internal components, damaged coils etc. Factor in an injector's cost plus cleaning and testing it and most of the time it does not pay to buy used when it comes to the smaller less expensive types.
Old Feb 15, 2003 | 02:34 PM
96ltz's Avatar
Re: Used Fuel Injectors
Your quick .
What does cleaning/testing cost, what would you say is the rejection rate of stock injectors with around 100k miles and around how much more life do you think they might have left in them?
Old Feb 15, 2003 | 02:46 PM
96ltz's Avatar
Sorry 4th-gen-formula, not meaning to take over your post .
To anser your question racetronix seems reasonably priced when I looked into larger injectors recently. Also seem to have great customer service from what I've seen on this board.
You might also check combination motorsports or tbyrne motorsports, both are very good to deal with.
Old Feb 15, 2003 | 02:47 PM
Racetronix's Avatar
Re: Re: Used Fuel Injectors
Your quick .
To flow-test and ultrasonically clean one injector is approximately $10.00. This does not include o-rings, filter screens or pintle caps which can add another $5.00.
When it comes to the health of your motor I don't see how playing the odds with your injectors is worth the small financial gain. We have seen injectors with one season on them that have been rotted out while injectors with 100K+ miles have tested OK. It is a function of their operational environment that determines their health.
Old Feb 15, 2003 | 03:43 PM
Racetronix's Avatar
Post
If you are looking for a smaller injector Racetronix will be having a sale on pulled Delphi/Bosch 28lb/hr injectors. These injectors will be cleaned, flow tested and sold with a limited warranty. These injectors are currently used on LS1 motors. They exhibit an excellent spray pattern for smooth drivability and idle as well high pressure capability. These are the next generation types which are superior to the older SVO/Bosch style pintle injectors. Being an OEM GM injector standard style connectors are used and they are a direct fit. The price for a set of eight will be less than that of the Bosch SVO injectors.
This sale will start in 2-3 weeks.
Old Feb 16, 2003 | 06:06 AM
sscott's Avatar
Those injectors say they are for a Ford Mustang, will they work on my Camaro, and how do I know that they are flow tested. I got screwed on some Bosch 30# SVO injectors which I thought were flow tested until I found out that they were "Old Type" injectors. Now I'm out $225 and have to get new ones. A word to the wise, do some research before you dive in. I had to learn the hard way.
Old Feb 16, 2003 | 07:26 AM
nateh's Avatar
The SVO's will work. They are what many people are using to upgrade their injectors. I have a neighbor who is using them with no problems.
Old Feb 16, 2003 | 12:10 PM
Racetronix's Avatar
Many people do use SVO injectors.
SVO injectors do not come flow matched from the factory.
This is a service that is provided by specialty suppliers.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
