Fuel Injectors
Old Jul 26, 2009 | 02:17 AM
joshmullins8's Avatar
Arrow Fuel Injectors
Im running the LT4 Hot Cam kit and .030 flat top pistons and my furl injectors arent any good, which injectors should I get? Brand? lbs?
Old Jul 26, 2009 | 02:40 AM
MikeGyver's Avatar
Stock. u won't have to retune.
Old Jul 26, 2009 | 06:59 AM
How did you determine your fuel injectors aren't any good?
Old Jul 27, 2009 | 12:13 AM
Im actually thinking now that it might be fuel pump cause someone told me that there is something by my cowl that you press and if it shoot out gas hard then the pump is good but it shot out weak, so Im guessing its a bad fuel pump now
Old Jul 27, 2009 | 01:20 AM
93FIRETURD's Avatar
go to your local parts store and pick up a fuel pressure tester they run about 25 bucks, check your pressure and you should see 41-47 psi at idle if not you may have a bad pump or a clogged fuel filter
Old Jul 27, 2009 | 05:19 AM
You test the pressure at the Schrader valve, on the fuel supply hard line.... that's where you would do the "if it shoot out gas hard" test, which is not accurate at all. Use a gauge as suggested above.
http://shbox.com/1/fp_reg.jpg
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
