Fuel Injectors
Im actually thinking now that it might be fuel pump cause someone told me that there is something by my cowl that you press and if it shoot out gas hard then the pump is good but it shot out weak, so Im guessing its a bad fuel pump now
You test the pressure at the Schrader valve, on the fuel supply hard line.... that's where you would do the "if it shoot out gas hard" test, which is not accurate at all. Use a gauge as suggested above.
http://shbox.com/1/fp_reg.jpg
Jul 4, 2005 05:00 PM
