fuel injectors
Old Mar 15, 2009 | 01:08 PM
speedcrazy's Avatar
fuel injectors
I am just wondering if the stock 24lb injectors out of a 95 fbody will work in some other makes and model vehicles?
Old Mar 15, 2009 | 01:24 PM
Most GM products use the same connector and physical size injectors. Whether they match the flow rating is another story. Similar year Mustangs use the same connector, similar flow ratings, but the Ford injectors are very slightly shorter, might be a tight fit.
What car/engine do you have in mind? Otherwise the question is way to broad to answer.
Old Mar 15, 2009 | 01:31 PM
speedcrazy's Avatar
thanks for the info. I was just looking at selling these ones so i just wanted an idea if there were any other known vehicles these will work on when i advertise. thanks.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
