Fuel Injector Rail Removal
Old Jun 10, 2005 | 11:32 PM
BigJustinZ28's Avatar
hey , Ive noticed lately my car has been leaning out the right bank alot , to the point of it starting to detonate. Its always done this a lil but never detonated until now. Im gonna pull the fuel rail and prime the system and see if one is leaking. Is it as easy as it looks ??? 4 bolts and then just lift ??? never had to pull it before.
edit: Oh yeah , already replaced front o2's . put new plugs and wired in a lil less than a year ago.
Old Jun 10, 2005 | 11:42 PM
sssalah's Avatar
Re: Fuel Injector Rail Removal
If you only want to lift the rail then it's just the 4 bolt and a little prying to take injectors out the holes. If the total removal of the rail is required then you must use a special tool (Fuel rail or AC line disconnect) to disconnect the feed and return lines to the rail.
Old Jun 10, 2005 | 11:45 PM
OBE1 95Z28's Avatar
I suggest pulling the plugs and inspecting the color to see if you have a problem with a particular cylinder or the entire bank. If you decide to lift your fuel rail, use compressed air to blow off the manifold around the fuel injectors to keep dirt from falling into the holes once the fuel rail is lifted. As you stated, it's four bolts and lift. Apply oil or silicone grease to the injector o-rings to aid reinsertion of the fuel rail.
Old Jun 10, 2005 | 11:52 PM
blackztpi's Avatar
its rather easy... don't let special tools intimidate you... it's an 8 dollar tool from the autoparts store, although it can be tricky to get into the fitting. it's worth removing. much easier to work on that way
Old Jun 11, 2005 | 09:31 AM
if I pull out the four bolts will I be able to move the fuel rail about a foot ??? Is anything else holding it down in that area besides the 4 bolts ??? I dont need it outta the car I just wanna test if one of the injectors is leaking. I know the fuel lines reach all the way to the front and are flexible. I dont know about the electrical harness for the injectors tho.
Old Jun 11, 2005 | 09:36 AM
Feenix's Avatar
With the harnesses connected you wont have much travel area, you will how ever have a little bit more without them.
Old Jun 11, 2005 | 11:34 AM
breakmyfootoff's Avatar
You should'nt need the harness connected to see if one is leaking. The rails will pressurize without the harness to the injectors. Just remove the plugs from the injectors, f=remove the four 10 mm bolts and pry gently to remove the rails and injectors. As soon as you turn the key on the fuel rails will be pressurized.
Old Jun 11, 2005 | 11:59 AM
argh brainfart , I knew that already but it didnt register lol. Im gonna get some tape and number then so I dont mix them up. I should be able to do this either tonight or tomorrow. I hate to say it but I hope one is leakin , thats the easiest thing I can think of that would cause one side to run rich and not the other besides the o2's .
Old Jun 11, 2005 | 04:49 PM
pHEnomIC's Avatar
I took my rails off to check them. I cant find the o ring to #4 anywhere. i assume it fell into the fuel port. Do i need to fish it out/ removemy intake or will it just get burnt up? Is it alright for me to just replace it or do i have to get it out for sure?
Old Jun 11, 2005 | 05:17 PM
I think this is going to be a personal preferance issue. That being said, if it were my car, I would want it out. I probably wouldn't hurt anything, but I would worry about it leaving a residue on the piston causing a hot spot. There's always the chance that it could bend a valve also. I'm not sure about the actual possibility of either of these happening, but I personaly would not want to risk it.
Old Jun 11, 2005 | 05:45 PM
pHEnomIC's Avatar
I found the oring, thanks for the quick response. Blew compressed air at the side of the engine for a few mins and it showed up on the floor so im happy.
Old Jun 11, 2005 | 08:18 PM
ZMAN Z28's Avatar
I just checked my injectors yesterday. I removed those 4 bolts, then pryed up the fuel rail. I suck a file underneath the rail to prop it up so I could view the injectors spray. I disconnected the coil wire so car wouldn't start. Just hace someone turn the car over, and observe the injectors spray. They should come out like a mist in a conical fashion. It will amlost look like a steady conical mist because they are turning on/off very fast. I'd look for any irregularities between the spray patterns.
ZMAN
Old Sep 8, 2013 | 07:54 PM
JFR's Avatar
JFR
I got the ac disconnect tool. It goes into the fuel line and I feel a click, Line almost comes off, but then hangs up. Any tricks to go the extra to get it disconnected.
I am using a 3/8 inch delco disconnect plastic tool on the big supply line.
Any help, have to get rail off to change regulator.
frank
Old Sep 9, 2013 | 11:42 AM
Supply line is 3/8", return line is 5/16".
You are keeping the tool inserted when pulling the line out of the fitting, right?
Old Sep 10, 2013 | 10:43 AM
JFR's Avatar
JFR
Thanks Fred,
As it turned out, I went down to Napa and bought a metal fuel removal tool.
The lines came right off easily. Those plastic removal tools are not good.
Simple fix. You need good tools, not plastic junk.
Frank
AdsoYo
May 2, 2018 03:21 AM
QuickSilver02
Apr 7, 2015 11:12 AM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
