fuel injector help
Re: fuel injector help
Remove the 4 small bolts on the fule rail. Spray out the ports whrere the injectors go into the intake with brake cleaner or air. I took a screw driver and pryed up on the crossover tube slightly to get a better hold of the fuel rail. Then I lifted up till the injectors popped out. They might not come out that easy. Once you have the injectors out, they are attached to the rail by clips. Just pry them out, and you're done.
Z
Z
Jul 4, 2005 05:00 PM
