fuel injector help
Old Jun 18, 2005 | 08:54 AM
flounder564's Avatar
fuel injector help
how do i remove the fuel injectors
Old Jun 18, 2005 | 10:10 AM
ZMAN Z28's Avatar
Re: fuel injector help
Remove the 4 small bolts on the fule rail. Spray out the ports whrere the injectors go into the intake with brake cleaner or air. I took a screw driver and pryed up on the crossover tube slightly to get a better hold of the fuel rail. Then I lifted up till the injectors popped out. They might not come out that easy. Once you have the injectors out, they are attached to the rail by clips. Just pry them out, and you're done.
Z
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
