Fuel Injector?
Old Jan 13, 2004 | 11:24 PM
RedWS6TA's Avatar
Fuel Injector?
are the fuel injectors the same for the lt1 as the ls1. just wondering. and also dont the ford injectors work also.
Old Jan 13, 2004 | 11:30 PM
S.J.S.'s Avatar
Yeah they are but the LS1 runs at higher fuel pressure. I believe at like 58psi. Of course I'm probably wrong as usual.
Old Jan 13, 2004 | 11:53 PM
Kain's Avatar
In 98 they were either 28 or 30 pounders, then they came down a little bit in 99, where as LT1 injectors are 24 pounders, I believe.
Old Jan 13, 2004 | 11:54 PM
QCKZ28's Avatar
stock ls1 injectors do run at 58psi, they vary by year 26 or 28
stock lt1 injecotrs run at 43.5psi 24lbs (1994-1997)
so if you put a 26lb ls1 injector on the lt1 it would be downsizing.
but yes they are interchangable, and yes FORD SVO injectors work too, they are rated at 39psi
jesse
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
