fuel cut at WOT? little help
Old Apr 14, 2005 | 12:29 PM
94zLT1's Avatar
First of all i bought a fuel pressure tester and the thing was a piece of crap and leaked on me hence i could not get readings...
my car runs flawless at idle and any partial throttle.no knock and 02s look fine (via freescan)
Then at WOT i get shi^ loads of knock (like up to 6 degrees) and the 02s look dangerously lean..(fred u remember my thread(s) about this)
my question is..what is going on that on regular idle and any partial throttle the fuel is fine and then at WOT it is not giving as much fuel as needed?
Old Apr 14, 2005 | 12:55 PM
LiT1_up's Avatar
Re: fuel cut at WOT? little help
Fuel filter could be plugged up or you could have a weak fuel pump.
Old Apr 14, 2005 | 04:29 PM
94zLT1's Avatar
its not the filter..i just changed it...im hoping its not the fuel pump i quess ill have to run a pressure test to see whats going on...if it is the fuel pump i have a good write up guide on how to install by cutting through the trunk floor...would another stock pump be best route to go? if so what is the stock and where should i get it from?
Old Apr 14, 2005 | 04:41 PM
Z95m6's Avatar
Get a Racetronix pump kit.
Old Apr 14, 2005 | 04:47 PM
94zLT1's Avatar
is it needed or will the stock be sufficient? what r my options and where to get? what r people running that seem to be the best for a bolt on car? thanks
Old Apr 14, 2005 | 04:53 PM
94zLT1's Avatar
http://www.ls1speed.com/catagory.cfm...%20/%20Cooling
this is where i get my goods since it is 20 min from my house...which pump would i want..inline or intank?
Old Apr 14, 2005 | 04:55 PM
Z95m6's Avatar
The Racetronix kit is the only pump that is made to replace the stock one and still be for high performance applications. It will work with a stock car too. Most people go with the racetronix because it fits our cars perfectly is a high out put piece and a stock pump would probably cost just as much.
Old Apr 14, 2005 | 05:02 PM
94zLT1's Avatar
ok thanks where to find the cheapest?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
