Frozen Coolant, how overheating
Old Dec 27, 2004 | 11:19 AM
ellootre's Avatar
Frozen Coolant, now overheating
The other day I started up my Z to go to work, and this horrid churning/whirring sound errupted from my engine bay. Low-and-behold, my coolant had frozen solid, radiator, hoses, everything. So I took the radiator out and thawed it along with all the hoses. Then put them back in and filled with 50/50 green anti-freeze. Now the car is over-heating quick and leaking out of the front cover of the waterpump.
What should I check out and what could be wrong? There's no coolant smoke, and no signs of coolant in the oil, and it doesn't seem to be loosing coolant anywhere, it's just heating up fast.
Old Dec 27, 2004 | 11:21 AM
Re: Frozen Coolant, how overheating
There's a chance the water pump shaft or the drive gear broke when the impeller couldn't turn.
Old Dec 27, 2004 | 12:03 PM
Fuels94TA's Avatar
Ditto, the water pump is done.
Old Dec 27, 2004 | 01:21 PM
ellootre's Avatar
*sigh* Well that water pump is ordered and on the way. Thanks for the replies
Old Dec 27, 2004 | 04:37 PM
Or... to make your day even worse, the block might have cracked. Or, a simple fix... you popped a freeze plug loose and its losing coolant.
Old Dec 27, 2004 | 06:07 PM
faded93bird's Avatar
Check the WP drive shaft and make sure it dosent turn (the one coming out of the front cover) also.
Old Jan 1, 2005 | 12:29 PM
ellootre's Avatar
So as a follow-up for this, I pulled the pump off and got this:
http://www.iupload.net/102004/waterpump4.JPG
http://www.iupload.net/102004/waterpump3.JPG
http://www.iupload.net/102004/waterpump2.JPG
Thankfully the driveshaft is a-ok. Thanks for the help guys
Formula Steve
Sep 19, 2023 08:31 AM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
