Front wheels hard to turn...
Old Nov 8, 2003 | 10:21 PM
madwolf's Avatar
Arrow Front wheels hard to turn...
Anyone else have this problem? On my '93, you have to actually use some force to turn a front wheel. I can hear squealing so it must be the brake pad. (as opposed to bearings) Could the previous owner have installed the brakes incorrectly or is this normal? If I remember correctly, on my 95, the wheel would spin several times with just one push....
Thanks!
Old Nov 9, 2003 | 12:24 AM
SloLt1Z's Avatar
Check your tire pressure. If not that maybe the power steering pump. Those are the only things I could think of.
Old Nov 9, 2003 | 12:25 AM
T/A#4's Avatar
Unhappy
I just did my "end of season" oil change & noticed the same condtion on the front wheels of my 97, WTF ?
Old Nov 9, 2003 | 12:26 AM
madwolf's Avatar
Sorry, I must've not explained it correctly. I meant spinning the wheel when it's up in the air...
Old Nov 9, 2003 | 03:17 AM
93formula's Avatar
your brake caliper may be on crooked. if you take them off you will notice the part that you have to use the torx bit on moves, or should move freely. just grease em up and install them. that shoudl do the trick.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
dpw21562
Jan 23, 2015 04:58 PM
