Front Wheel Bearing and ABS
Old Dec 30, 2003 | 07:38 AM
athens96ta's Avatar
The driver's side front wheel bearing is goig bad on my TA. Will this trigger the ABS inop light?
Thanks,
Loren
Old Dec 30, 2003 | 08:05 AM
1fast95Z's Avatar
No, the bearing going bad should not affect the abs system.
Old Dec 30, 2003 | 03:01 PM
PGR's Avatar
PGR
If the wheel bearing is REALLY loose, it can trigger the ABS inop light. The ABS sensor and relector ring are integrated into the wheel bearing assy, so a really loose bearing will create an inconsistant reluctor gap, which can trigger the abs sensor.
Jack up the front of the car, and try to rock the wheel back and forth (grab it at the 12 and 6 o'clock position). There should be no play. If its more than a quarter inch of play, I would suspect it's triggering the ABS inop.
jj_burchiel
Mar 21, 2015 12:51 AM
warmeck
Mar 8, 2015 08:01 PM
Doug Harden
29
Jul 30, 2003 07:05 AM
z28projects4ever
133
Jul 26, 2002 01:54 AM
