Front Timing Cover Leak
OK I followed all of GM's instructions per the service manual and I even bought a BRAND NEW timing cover will all seals installed and I still get a drip out of the front where the oil pan meets the cover. WTF?? anyone know the easiest way (Without oil additives) to fix this
Check your CPS.. that's where mine likes to leak from.. it doesn't really drip though, just kinda seaps out.. wish I had eliminated it completely when I did my cam install.. less crap to worry about.
Had it on the lift, looked like it was coming from bottom but I didn't check CPS Thanx, I'll look there before moving on!!! It's about the only thing I didn't replace as converting to OBD1 doesn't Require it
oldschool
Feb 9, 2016 09:21 PM
