Front Timing Cover Leak
Old Apr 15, 2003 | 08:51 PM
JOE96Z28SS's Avatar
Angry Front Timing Cover Leak
OK I followed all of GM's instructions per the service manual and I even bought a BRAND NEW timing cover will all seals installed and I still get a drip out of the front where the oil pan meets the cover. WTF?? anyone know the easiest way (Without oil additives) to fix this
Old Apr 15, 2003 | 09:06 PM
Sounds like the pan seal, not the timing cover. Did you drop the pan down before putting the timing cover on?
Old Apr 16, 2003 | 08:31 AM
JOE96Z28SS's Avatar
Yeah, Engine was on stand Upside down when Oil pan was installed plenty of sealant in the corners too Just like GM Says
Old Apr 17, 2003 | 01:06 AM
Lt1t56's Avatar
Just a thought. The water pump drive seal is tricky to install, if leaking from there, it will run down the timing cover and drip where the timing cover meets pan.
Old Apr 17, 2003 | 01:13 AM
Javier97Z28's Avatar
Moderator
Check your CPS.. that's where mine likes to leak from.. it doesn't really drip though, just kinda seaps out.. wish I had eliminated it completely when I did my cam install.. less crap to worry about.
Old Apr 17, 2003 | 08:27 PM
JOE96Z28SS's Avatar
Had it on the lift, looked like it was coming from bottom but I didn't check CPS Thanx, I'll look there before moving on!!! It's about the only thing I didn't replace as converting to OBD1 doesn't Require it
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
