front sway bar?
Old Feb 26, 2003 | 11:19 AM
dansmysticta's Avatar
front sway bar?
Why do people remove their front sway bar? Thanks.
Old Feb 26, 2003 | 11:21 AM
Ben Ramsden's Avatar
i've never heard of anyone doing this, if so, I too have no clue why? Unless to put on a larger one, stock is pretty small, a.k. weak.
Old Feb 26, 2003 | 11:28 AM
IDOXLR8's Avatar
People typically do this for drag racing. It lightens up the front end and gives you better weight transfer. I personally would not do this on a car I drive everyday. The front sway bar has a huge impact on how your front end handles.
Old Feb 26, 2003 | 11:41 AM
TedH's Avatar
Removing the front sway bar frees up a few pounds of weight on the front. It also allows the car to sie up more easily which facilitates weight transfer to the rear wheels facilitating better traction.
My front sway bar has been removed for several years. Removing it did not adversly affect my handling under normal street driving conditions. However adding lightweight skinny rims and tires,drag shocks and springs, in conjunction with front sway bar removal certainly destroyed my ability to negotiate off ramps at high speed.
Old Feb 26, 2003 | 01:04 PM
I would not recommend leaving it off for daily driving. Your car's suspension was designed with a sway bar as an integral piece. IMO, removing the bar would cause an imbalance in the cars handling predictability, especially in a situation like an accident avoidance maneuver. It is then you want your car to do exactly as you expect. I don't know why anyone would want to intentionally make their car less capable in this regard than when it came from the factory.
Take it off for the track if you want, but put it back on for daily use. MHO.
96SilverRam
Nov 20, 2016 11:19 AM
Alien
Jun 27, 2015 01:13 PM
96SilverRam
May 5, 2015 09:56 PM
BLK1997Z28
May 1, 2015 12:23 PM
8T8IROC
Mar 26, 2015 09:02 PM
