front oil leak.... just need a part number
Old Jan 12, 2006 | 04:21 PM
ppa95z28's Avatar
the rubber seal that goes on the bottom of the timing cover and seals against the oil pan.... does anybody know the part number for this part... or will i have to buy a new cover. thanks
Old Jan 12, 2006 | 04:29 PM
jsetzer's Avatar
Re: front oil leak.... just need a part number
Bottom? Thats the oil pan gasket. Its one piece and wraps around/up from the pan rail.
Old Jan 12, 2006 | 04:32 PM
ppa95z28's Avatar
oh der her... lol sorry for that.... it looked like a different piece.
Old Jan 12, 2006 | 04:37 PM
jsetzer's Avatar
Did it rip pulling the cover off? its really typical to happen. We tore mine while swapping the cam and said there was no way were were going to drop the pan, so I slabbed it up with rtv and bolted it back together. It leaked quite a bit but didn't pour, figure I will do it right now that the motor is apart.
There is a gasket that is shaped like a horseshoe that goes behind the top part of the cover, the bottom is actually the lip of the pan gasket.
Old Jan 12, 2006 | 06:23 PM
Jazsun's Avatar
damnit mine is doing the same thing, just a couple drops at night when its cold not much.
Old Jan 12, 2006 | 10:58 PM
silentsprintero's Avatar
mine leaks a lot and maybe it has to do something with when my buddy installed the hotcam kit when he had it? not looking forward to fixing this but it leaks more than i'd like...
Old Jan 13, 2006 | 12:53 AM
sssalah's Avatar
No way around it with these motors, lowering the front portion of the pan an inch or so is necessary to avoid damaging the pan seal. Wish it was as easy as LS1 motors, where you don’t have to think about the pan and intake.
Old Jan 14, 2006 | 03:00 PM
ppa95z28's Avatar
yeah it ripped when i did the optispark and electric water pump install. but i put it back together and it didnt leak oil so i thought that was how it was made.... but looking at it i see how it goes now. i actually have the engine out and i am rebuilding it due to a spun rod bearing.
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
CobraEatr
Jul 22, 2002 09:49 AM
