Front and Mid mount motor plates, any significant advantage?? Who uses them??
Old Apr 1, 2005 | 10:27 PM
Camaro_Guru16NY's Avatar
-john
Old Apr 2, 2005 | 12:33 AM
1racerdude's Avatar
Re: Front and Mid mount motor plates, any significant advantage?? Who uses them??
Unless you have a trailer queen there is no need for them. If you aren't running in the nines there is no need for them.
The big advantage is you can put the engine where you want and the mid plate helps with broken bellhousings.If you use both motor plates don't use a solid tranny mount,you will break the tail housing.
HectorM52
Jul 30, 2017 11:46 AM
Richardan15
May 30, 2015 08:36 AM
heavenly_six
Dec 10, 2014 12:23 AM
Mad_Ice
Jul 29, 2002 09:44 PM
