Front end trouble
Front end trouble
Do I have to compress the front spring to take off the lower A-arm? I took off my caliper to paint it and found a busted bushing on the rear mount of the lower A-arm. Also, where does everyone put thier jack stands on the front end?
You don't have to compress anything. When the car is jacked up and wheel hanging free, there is very little, if any, compression on it. Depending on what you are working with, you should be able to find a way to put stands under the K-member. If not, put them under the pads at the front of the front fenders.
Originally posted by SWINGRRR
Cool.
Mr. Box, can you verify this is the P/N for the 1LE bushings for the front lower contol arms,
Ft(Horizontla):17999114
Rear(Vertical):17999112
Cool.
The parts book does not even list the bushings separate from the arm.
THNX I called Cromer and he's got me a set on the way. When I get them in Ill send you the numbers, if you want.
Just for furture reference.
They are $17 (HZRNT), and $38 (Vertical) bucks a side.
Regulars were about $20 a side for both.
Cool.
Cool.
