Front Clip?
Front Clip?
This winter i want to do cam/head swap and i was told the easiest way to do it is drop the engine out the bottom of the car. Yesterday i was at a friends house and they told me it would be much easier to remove the front clip. Im not sure how i would go about this or what would have to be done? what do u think?
Re: Front Clip?
You still wouldn't have to pull the front clip. I'm currently in the middle of a cam swap and i still the the front clip on the car. To get the heads off with the motor still in the car would be more difficult but i don't see why its not possible
Originally Posted by JDM-93_Z28
well if we took off front clip we could keep engine in the car and do cam/heads...?
Check shoebox's web page you don't have to go through all that.
http://shbox.com/ci/cam_install.html
Chris G.
Re: Front Clip?
Re: Front Clip?
when i did my cam swap, i just pulled the radiator and condensor and all hoses out of the way. there is definitely plenty of room for the cam swap in the car. i drove my car to my dads garage let it cool and had the cam out in less than 2 hours. (my dad has done this many times which helps.) the heads could be trick but are managable.
Caps94ZODG
25
Oct 2, 2003 06:30 AM
