Fried PCM?
Old May 20, 2005 | 05:55 PM
weinerschizel's Avatar
Fried PCM?
I was working with tunercat. Went to upload a file and in the middle of erasing flash memory it said error, can not establish connection... bad cable... something to that effect.
I think my PCM is now fried. How do I make for sure its that and not something else. I'm pretty sure it's that as when I go to turn the motor over all it does is spin the motor. Or so it seems.
Old May 20, 2005 | 06:01 PM
madwolf's Avatar
Re: Fried PCM?
If you were programming (not reading) then yes, it is fried.
I repair them if you're interested.
Old May 20, 2005 | 06:13 PM
Re: Fried PCM?
What would you charge me to repair it and slap a base tune on there?
that or just to repair it. I also have a bunch of programs I made but they're pretty much junk.
I've got a 1994 Z28 w/ the following mods
K&N CAI
Lightly ported and polished heads (by me just cleaned up the castings and portmatched intake to heads)
cc306 cam
1.6:1 full roller rockers
electric water pump
adjustable fuel pressure regulator set to 45 psi
removed smog pump
removed muffler
I think that's about it. Thanks for your help!!!
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
