Fresh dyno numbers
Old Nov 22, 2006 | 02:56 PM
  #16
MeanGreen97Z's Avatar
You seriously need a tune. 1.6 rockers, new springs, ewp, 52mm TB, coolant bypass, and maybe even some 1.7 rockers if you wanna try it. You could pick up a good bit... just have to wanna do that.
Old Nov 22, 2006 | 03:13 PM
  #17
etex95's Avatar
tune is deff comming in the next month or so, the 1.6's and springs would be nice if i can find the money. dont want to get ewp just had new wp put on last month. maybe tb if i can get a good price
will the valve covers clear the rockers'?
with this what would i be looking at hp/tq wise?(1.6, tune, springs)
Old Nov 22, 2006 | 03:23 PM
  #18
I have some lt4 valve springs and 1.6 roller tip rockers, not full roller rockers. Total price.... less than 100$. LOL Ported stock TB to 52mm with an airfoil from eBay have been great for people here and are 120$ plus core. If you send him your TB he can port it and add a airfoil. Cost is like 150$. For 250$ you can pick up about 15 at the wheels I bet.
Old Nov 22, 2006 | 11:07 PM
  #19
etex95's Avatar
with this plus tune where do u think i'd be?
Old Nov 26, 2006 | 07:36 PM
  #20
etex95's Avatar
here is the response from my e-mail to dallas mustang:
The roughness of the lines is possibly from some rf noise through the ignition system or the plugs are miss-firing. You may consider changing plugs.
The A/F lines at the bottom are the actual A/F (smooth line) and the target A/F (dotted line).
what do yall think?
Old Nov 26, 2006 | 08:10 PM
  #21
Tune and 1.6 rockers could put you over 280rwhp. What they said is likely. I would change plugs and the tune would help to even out that line.
  #22
Steve0's Avatar
what do yall think?
How many miles are on your car? How old are the plugs and wires?
You dont notice any vibrations from the engine when accelerating under load do you?
Old Nov 26, 2006 | 08:25 PM
  #23
etex95's Avatar
wires: 1 year or so
plugs: less than a month
110,xxx miles
and no im not feeling anything unusual when accelerating
Old Nov 26, 2006 | 08:38 PM
  #24
Steve0's Avatar
I'd say your ignition system is alright then. Most dyno graphs I have seen where the ignition system is faulty usually have sharper, more erratic looking waves.
I'd really get another pull... preferably on a different dyno if there is another shop local to you. These guys dont seem to know what they're doing as I dont know why these guys would stop your run at 5200rpm. Like previously stated, you cant really verify that 260rwhp peak because it looks like a spike. My bet is the problems are with the dyno you tested your car on.
Old Nov 26, 2006 | 08:53 PM
  #25
etex95's Avatar
after i get my tune in the next month or so ill head back out.
i only know of one other place in the area so options are kinda limited
Old Nov 26, 2006 | 09:30 PM
  #26
Sweetred95ta's Avatar
Every other dyno chart I've ever seen had a target a/f of 13:1. The spikes don't appear to be anything related to a mis-fire or ignition problem. Post back up after you do another pull.
Old Nov 26, 2006 | 10:36 PM
  #27
Bring your tail out here to Dallas and go to HPP. They can dyno tune your car.
Old Nov 27, 2006 | 07:55 PM
  #28
etex95's Avatar
probably will after christmas, where's it at?
Old Nov 27, 2006 | 08:09 PM
  #29
etex95's Avatar
It looks like the car is running a bit lean and has a good bit of knock retard. Has it ever been programmed before? That is odd to see if it is a stock tune as typically they run on the rich side from GM. One possibility is that the MAF is very dirty and not reporting all the incoming air (easy to clean, just spray with some carb/choke or throttle body cleaner), or you may have a leak after the maf on the intake boot. Either can do this.
Brian from pcmforless.com when i asked about a tune
Old Nov 27, 2006 | 09:06 PM
  #30
'94 Bad A Z28's Avatar
I say there is prolly more left in the car, here is my dyno chart with just SLP CAI/Yank 2800 converter and then + a 100 shot. (stock tune)
