free weight reduction ?
Old Oct 21, 2003 | 09:27 PM
NEOS97SS's Avatar
weight reduction
taking out:
spare
jack
flap cover thing
back seats
passenger seat
right now thats about all i can think of to lower the weight without goin all out and doing something obscene. are there any other 1/4 mi freebie mods i can do
Old Oct 21, 2003 | 09:31 PM
jasons93z's Avatar
Air pump thats at least 3 pounds, but it does clear up some of the engine bay so i would do it. All i have out of my car is the jack, and spare.
Edit: I think its stupid IMHO to remove all that stuff just to go to the track. Im not trying to rag u but are you trying to prove something, or racing for money? When i go tothe track i keep it like i do on the street.
Wild1's Avatar
The spare maybe 15 lbs.
Jack 10 lbs.
Back seats 7 lbs each
Passenger seat maybe 25 lbs.
Old Oct 21, 2003 | 09:36 PM
97WRAITH's Avatar
A/C system,padding under the carpet, Abs unit,front sway bar and brackets.
Old Oct 21, 2003 | 09:37 PM
QCKZ28's Avatar
carpet padding
i removed one horn (other works good enough)
trim panels that go above your feet, (you cant see them anyway)
front sway bar and brackets (unless you like to take curves fast)
heat shields above the exhaust system
EGR system
Old Oct 21, 2003 | 09:40 PM
jasons93z's Avatar
Originally posted by QCKZ28
carpet padding
EGR system
Do u know if there is a write up on how to remove all the egr stuff. Not for wieght, just its in the way of everything.
Old Oct 21, 2003 | 09:43 PM
RangerBob's Avatar
The driver can go on a diet, also take exlax wat before a race
Old Oct 21, 2003 | 09:49 PM
QCKZ28's Avatar
to completely remove the EGR-remove the egr tube that goes from the pass exhaust manifold to the back of the intake manifold, remove the egr valve from the drivers back side of the intake manifold, then make/buy 3 blockoff plates to cover all the holes you uncovered and make sure they are sealed up with new gaskets/rtv.
run a search there should be lots of info on this topic. its really easy, one of the first things i did
jesse
Old Oct 21, 2003 | 09:52 PM
jasons93z's Avatar
jesse
did you notice any difference in how it drove. I wouldnt think so, just wondering.
Old Oct 21, 2003 | 10:00 PM
BlakeW5's Avatar
As far as weight, when I weighed out things I removed I got:
Spare: 27lbs.
Jack: 8-10 lbs.
Rear seat pads (part you sit on): 5lbs. a piece
Rear seat back: 16lbs.
Trunk/Hatch cover: 4lbs.
Plastic in the trunk/spare area: around 4lbs. total
Rear seat belts: 5lbs each
Not too much of a weight reduction, but it has to help and gives you an excuse to not cart all your friends around . I heard something about the passenger seat being around 40 something pounds. So just removing a few trivial things when you go to the track can save you 100ish lbs. and 1/10 of a second.
Old Oct 21, 2003 | 10:03 PM
NEOS97SS's Avatar
i already removed the air pump and all the egr bs when i did my longtubes.
and does anybody know exact weight of seats and spare and jack
i need my heat shields this is a daily driver im just doing this for a track day thing to see how quick i can make her.
and i consider removing the carpet padding a little obscene.
any other suggestions...
Old Oct 21, 2003 | 10:44 PM
QCKZ28's Avatar
are you talking about removing interior and door panels and stuff like that? then put it back after you race?????
Old Oct 21, 2003 | 11:20 PM
JodyJ's Avatar
Here's a web page I found on Brent's web site.
http://www.bfranker.badz28.com/fbody/weights.htm
Jody J.
Old Oct 22, 2003 | 12:42 AM
jonaddis84's Avatar
I was curious whether removing the heat shields above the exhaust and the panels abover your feet were weight reduction or just getting them out of the way, I cant imagine that stuff weighs more then 5 lbs together if your lucky, that calculates to about .005 of a second in the quarter, and the way i see it, and proved it, i took out my speaker box in the back, about 50+lbs to go to the track once and ran a slower time, cuz i couldnt hook up.
Old Oct 22, 2003 | 12:58 AM
edg1957's Avatar
Sway bar is an easy remove and it helps with wt transfer. (The nose is lighter so it can shift up to load the rear easier. Some people have said removing wt on the back of the car has no effect, but I don't subscribe to that theory. My track prep is removing the sway bar, rear speaker panels, 12 disc changer, rear seat and belts, sunroof panels, floor mats, and any extra crap in the car (even loose change, etc) Several of my buddies leave their sway bars off nad have no problems even with serious driving. It seems to drive fine to me without it too.
Ed
