Found out why car dies!!!!
Old Apr 12, 2007 | 07:35 PM
ChevyTuffD.A.'s Avatar
Ive been having a problem with my car just dieing randomly on me and would not start back up unless sitting for a long time. I decided to try my luck and go to the track last weekend. I made it all the way to the track with no problems. I parked the car to let it cool down and about 2 hours later I went to make a pass. I got in the car and what do ya know, it wouldnt start. I knew the problem was fuel related but couldnt figure out what was up. So I had my buddy bring is tools over to my car. I did the fuel pump trap door method a while back (thank god) so I unbolted the fuel pump and pulled it half way out. I noticed the connector up at the top wasnt on there all the way. So I pushed it on there further and had my wife turn the key, woohoo the fuel pump turned on. So I bolted the pump back in and made 2 passes and drove her all the way home with no problems. What a relief to finally have figured out what was going on with the car. Thanks for reading. Dustin.
Old Apr 12, 2007 | 08:24 PM
Severous01's Avatar
that's what troubleshooting is all about.
check the relay...check the fuse...check the wiring, check the unit...that's about all that's in the circuit other than the switch...
good find, and a cheap fix. about an hour's work and some friends.
Old Apr 12, 2007 | 08:41 PM
Yea I was so glad thats all it was. Only took about 20 minutes
Old Apr 12, 2007 | 08:56 PM
Voridaeus's Avatar
Thank you for posting your solution. Hardly anyone ever does that, but if they did we could all search and find the answers to most of our "gremlin" threads.
Old Apr 12, 2007 | 11:13 PM
mrmint69's Avatar
On the starting problem i solved. The car would not start if i tried to start it warm or hot. The starter was expanding so the contact was not made until it cooled down. I have never heard this before but hope it helps others.
Old Apr 13, 2007 | 07:53 AM
Guest47904's Avatar
Guest
Originally Posted by ChevyTuffD.A.
Ive been having a problem I noticed the connector up at the top wasnt on there all the way. What a relief to finally have figured out what was going on with the car.
Don't get me wrong but if that were indeed the problem the whole time, wouldn't a fuel pressure check have detected it? Or even as simple as relieving the pressure by hand at the schrader valve and then cycling power and pushing the schrader valve again to see if pressure had built up.
I seriously doubt that was the problem. If you think about a connector that was not seated properly. Wouldn't you have a problem when you hit bumps for example?
I hope it was the problem, but ?????????
Old Apr 13, 2007 | 03:13 PM
I did check the fuel pressure. That is how I knew it was fuel related. I tracked it down to the pump because after the car would die, I could not hear the fuel pump turning on, therefor I knew it was the pump. Also, I know it was the connector because when I pulled the pump out, the second I pushed up on the connector and had my wife turn the key, the pump turned on. To eliminate it just being a hoax, I pulled on the bottom of the connector with just a little pressure and had her turn the key, fuel pump didnt turn on. Pushed back up on the connector, turned the key, fuel pump turned on. I am positive that was the problem.
Old Apr 13, 2007 | 03:44 PM
2000GTP's Avatar
If that was indeed the problem, your fortunate it was an easy fix.
bfmv13trivium
Jan 14, 2015 09:57 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
