..Found my Annoying Squeak..now i need a quick fix..ideas?
Old Oct 24, 2004 | 09:09 AM
5.7LT1Formula's Avatar
After my rebuild i had a very annoying squeak...i had this before my rebuild..and i thought it was my old belt..because if u spray lube on the belt it would stop squeaking...well i has a new belt and still doing it.
I've found out that my Airconditioning pump is getting so hot that it is causing the belt to squeak....is there any way to disengauge the clutch on the AC pump? i would like to drive my car today being that it is one of the last nice days we will have this year...any help would be great
Old Oct 24, 2004 | 09:19 PM
TobyZ28's Avatar
Re: ..Found my Annoying Squeak..now i need a quick fix..ideas?
umm, you sprayed lube on your belt??
Old Oct 24, 2004 | 10:46 PM
n2ceptor's Avatar
If the A/C is not on, then the A/C pulley travels free.... Is the pulley locked???? If so, then you need a new compressor or an A/C delete pulley kit....
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
cristian1311
Sep 12, 2015 08:16 PM
