found a header bolt to be missing, problems from that??
Old Apr 30, 2004 | 09:08 PM
sc93's Avatar
Well I just noticed that a header bolt is missing from in front of the #8 primary tube on my AS&M's...
could this have been causing any possible leak? running rough?
Old Apr 30, 2004 | 09:14 PM
Rashiki's Avatar
I was missing a bolt on the back of my #8, and i had no idea until i heard a leak and replaced the gasket.. You'd hear a leak first.
Old Apr 30, 2004 | 10:29 PM
"White Knight"'s Avatar
Don't get me started on bolts falling out...
It's a long story but the just is i use Dead soft aluminum gaskets and i told the dealor they need to be crushed and to over torque them.......well guess what they didn't listen......so i'm driving down the road...(pedal to the floor like always) I hear this ping and sounded like something hit the firewall.......i look up in my rear veiw mirror and i see this little black thing bouncing behind me........i was like hmmmmm must have been a rock get home......was like 1/2 mile away....and find a bolt missing.....it was the front one gasket had burnt through.
Lets just say they bought the 50 dollor gasket and put it in for free.
But in your case the gasket may or may not have bunt through--what type is it? Try bolting it back down and seeing if it leaks----if it does replace the gasket
Old Apr 30, 2004 | 10:36 PM
sc93's Avatar
It is a Fel-Pro gasket
Old May 1, 2004 | 10:20 AM
Bud M's Avatar
Could it cause rough running or leaks? Sure.
Maybe you should get a set of Stage 8s.
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
