Found a cut wire near tranny HELP!
Old Jun 23, 2003 | 08:49 PM
Z28Flames's Avatar
I finally got my Z28 back on to the road today and had trouble shifting.. (A4)... came back, jacked it up and there are 2 wires hanging from the back of the tranny..... one purple, one yellow... i need to know where they are suppose to attach so i can hook them back up, looks like they got cut or came loose, but they are now only attached by the tailhousing of the tranny and look like they should run up towards the engine.... any help in finding the correct location would be great... thanks guys
Chris
Old Jun 23, 2003 | 09:09 PM
The VSS has yellow and purple wires. Can't you just find the other end and splice them back together? They go to the PCM .
Old Jun 23, 2003 | 10:52 PM
Z28Flames's Avatar
i dont see the other end of the wires. i need to know where they run to so i can trace them and splice them back... a wiring diagram or which side of the engine comparment they are suppose to run along or anything of that nature would be a big help so i can get this thing back off the jack stands... thanks guys
Old Jun 24, 2003 | 01:39 PM
Z28Flames's Avatar
TTT Help!
Old Jun 24, 2003 | 01:54 PM
The diagrams I have seen look like they show the wiring coming down the RH side and part of it crossing over the top of the tranny before it gets to the tailshaft.
Old Jun 25, 2003 | 03:43 AM
Z28Flames's Avatar
anyone else have any input??, thanks for the help so far shoebox
Old Jun 25, 2003 | 01:00 PM
Z28Flames's Avatar
ttt
Old Jun 25, 2003 | 01:24 PM
TransAm219's Avatar
ummmm I think he gave you the answer , just go fix it
Old Jun 25, 2003 | 06:26 PM
Stock Z's Avatar
A wire from my VSS once got pulled in two and my speedometer quite working and my A4 shifted from 1st to 3rd (had to rev high and it shifted hard) and not into overdrive. Reconnecting the wire (I think it was yellow but don't really remember) obviously solved the problem. The wire ran on top of the tranny and I reached it with my car up on a lift, from the passanger side, and I somehow managed to squeeze my skinny a$$ arm between the tranny and the floorboard, unclip a conduit of wires from 2 clips (i think it was 2) and pull them down (on the passenger side) to work on.
Good luck
Old Jun 26, 2003 | 02:09 PM
Z28Flames's Avatar
thanks for the help guys, and transam219..... thanks for being a dumb jacka$$.... if u dont know then dont post
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
mattszm6
Dec 14, 2014 07:09 AM
Teal94V-6
Aug 31, 2002 09:21 PM
