forward intake
Old Apr 24, 2004 | 09:46 PM
Z28Boss's Avatar
forward intake
I was wondering if anyone has ever tried to make their intake come right off the TB and go straight to the front of the car. Kinda like an LS1 type setup. You would have to get some kinda bellows from an ls1 that hooks up to your MAF, and then to your filter. I dont know if this is even possible. Let me know if anyone has tried it.
Old Apr 24, 2004 | 10:00 PM
simple's Avatar
sure its called the LT1 WS-6 Ram-Air airbox intake
making one prolly wouldnt be too difficult, bellows, MAF to airbox
Old Apr 24, 2004 | 10:01 PM
StrokerWannaB's Avatar
i have not tried it, i have seen it done though. The filter was angled a little downward. Other then that, it looked nice. Don't know if the air would be any cooler though. My Moroso sticks down to the front damn...it would be differnt though. GL
Greasepunk's Avatar
if i'm not mistaken, there is a ram air hood that uses a set-up like you are referring to. i wish i could remember what website had it, it was a hood/airbox combo.
Old Apr 24, 2004 | 10:04 PM
simple's Avatar
http://www.suncoastcreations.com/hoo...-97_camaro.htm
Old Apr 24, 2004 | 10:12 PM
Z28Boss's Avatar
Yeah, the air might not be colder, but wouldnt it flow GREAT. I dont know, this is just my thinking, with no ducting to go through. It would just be filter, maf, bellows, and TB. All in a straight shot.
Old Apr 24, 2004 | 10:22 PM
i can completely agree with that. I think you would be right. I like the hood, i just wish that it could be made a 4" rise cowl induction. I think it would look sweet as **** with 2 small slits like that in a cowl hood. O YEAH....
Old Apr 24, 2004 | 10:28 PM
Z28Boss's Avatar
I think I might mess around with this idea a little. How would I go from the circle maf end to the oval TB though, do they make some bellows like that for the LT1. I am sure something could be done. What is the actual diameter of the TB oval opening. Also, how much clearance is there between the radiator shield and the hood when closed? If anyone has answers to any of these questions lets hear em!!
Old Apr 24, 2004 | 10:34 PM
97WS6SCharged's Avatar
Go to Home Depot, in the plumbing section they sell rubber connectors. A 4" to 3.5" will fit perfectly and it will be a smooth bellows. I used one on my 97 Ram air for a while and it worked great. Oh, just remember to drill a hole for the opti vent.
There is no clearance between the stock hood and the top of the radiator. My ram air box had a 1/4" piece of foam/rubber thingy to seal it to the hood and that was it.
Old Apr 24, 2004 | 10:36 PM
as far as the bellows, get the measurements and go to a welder who works with the type of metal you wanna use. Give them the dimensions for the circle to oval and they will make one. Fabricators are AWEOMSE people to have around man.
Old Apr 24, 2004 | 10:40 PM
Z28Boss's Avatar
ONE MORE QUESTION. What kind of filter can I get that will lay down flat under the hood. I would probably need one that is a flat oval shape.
Old Apr 24, 2004 | 10:41 PM
simple's Avatar
look for stock replacement bellows off the 3rd gen cars, they have one that will work
Old Apr 24, 2004 | 10:42 PM
K&N makes one for the LS1 cars, but you're going to need a ram air style hood for it to fit.
Also, I wouldn't use an accordion sytle bellows, you want the intake to be smooth.
Z28Boss's Avatar
Hey, which end is the TB and which is the MAF. Is the 3.5 the MAF and the 4 is the TB??
Old Apr 24, 2004 | 10:46 PM
Z28Boss's Avatar
CRAP!!!! so your saying this wont fit under my stock hood. This will probably scrap this idea then. I wanted it to fit under my stock hood.
