Formula surges at red lights, HELP
I have a 94 Formula A4 stock except for K&N CAI.
When I am stopped at a light after warming up, my car surges
from600 RPM'S to 1000 RPM's then drop immediately back down to 600 RPM's. This will happen quite a few times with no particular pattern.
If I don't keep my foot pressed on the brake fairly hard it will lunge forward.
One more thing the air is not on and it dosen't matter if its night or day.
Any clues?
Any clues?
Originally posted by $hawn
Might try cleaning out your idle air control valve, also look for like a small vacumme leak.
Definantly a PITA.
Might try this;spray ever so gently some carb cleaner into the little hole in the throttle body where the iac sucks it's air from,then(like cleaning a rifle bore),use Q-tips (Plastic only,the wood kind break off),and stick them down into the little hole one at a time and twist them as to clean as much black stuff out as possible.This may take one half a box or so,but see if this helps.Hey,do the cheap stuff first.My02
(Like cleaning a rifle bore I ment clean it till you can see no more black stuff)Hope this helps.
I'd be willing to bet anything that it's the optispark.
My car was doing the EXACTLY the same thing that you described. We replaced the optispark while doing a waterpump swap and it hasn't surged again once since then. That was 1.5 years ago.
Not good news, sorry
Charlotte
Charlotte
