forged pistons slap
Old Dec 18, 2005 | 02:40 AM
lr383's Avatar
forged pistons slap
Hey any of you guys get piston slap when your motor is cold? this is my first forged piston short block. It goes after it gets warm, but it seems strange. just wondering if it hard on the cl walls It a 383. thanks.
Old Dec 18, 2005 | 06:14 AM
bdc95ta's Avatar
Re: forged pistons slap
It's typical for most forgings. Coatings help (mahle's). Forged pistons have a greater expansion rate then cast so the clearances must be larger to accomedate. Which also means increased blow by at start up.
-b
Old Dec 18, 2005 | 11:45 AM
lr383's Avatar
thanks for the reply. Iam giong to call JE pistons and ask them about coatings.
Old Dec 18, 2005 | 12:44 PM
bdc95ta's Avatar
there ridiculously expensive, I would suggest some hyper's.
-b
Old Dec 18, 2005 | 02:19 PM
MachinistOne's Avatar
You have a short skirt piston in that 383 too, that makes the slap worse. How much piston to wall clearance is there?
Old Dec 18, 2005 | 03:35 PM
Steves396lt1
Guest
Posts: n/a
JE/SRP has two different forged pistons. They will explain them to you. I think there SRP pistons are more for a "street" car(more silicon in piston?) and the JE pistons are more "race". I have the SRP pistons in my 396 and there is no slap when cold. Of course, it is Hawaii here, so its about 80 degrees when I start it regardless.
Old Dec 18, 2005 | 04:05 PM
1racerdude's Avatar
It won't hurt a thing IF it is piston slap.
Get use to it.
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
