Forged 383 Le2 Setup
Old Mar 10, 2006 | 11:29 AM
playa7970's Avatar
Ok this is my current setup on the way :
383 Golen Comp Lt1 (Forged)Internally Balanced
LE2 Heads , Cam , Intake manifold
Comp 1.6RR (including Studs 7/16)
Comp Oem Lifters
Comp Pushrods
Gm guide Plates
Complete Gasket Kit
ARP Bolts (Head, Intake)
Oil Pump Kit
Oil Pan
Meziere Water Pump
Cloyes Chain
160 T-Stat
58mm Holley TB
36Lb Injectors (Ford MotorSport)
internal balanced flexplate
4L60E (Stock)
Rear End (Stock)
Computer (Stock)
What else am i going to need with this setup, and i know my stock a4 wont handle it as well as my rearend plus i need a tune i know, But would the car last a month driving it normal and what type of fuel pump would i need (sorry for all the questions!
Old Mar 10, 2006 | 12:26 PM
J Rod's Avatar
Re: Forged 383 Le2 Setup
Hey, that's the exact same setup I'm aiming for only mine's an M6. Just need about $2k for the top end and fuel system, might be a while. lol When you get that thing tuned and running good, you'll have to post some dyno #'s & ETs. Good luck with the install!
Btw, on top of just about everything else you listed... I was going to go with a 255 Walbro in-tank pump. I guess if that's not good enough, someone will chime in and let us know.
Old Mar 10, 2006 | 01:45 PM
playa7970's Avatar
does anyone know??
Old Mar 10, 2006 | 02:50 PM
TraceZ's Avatar
Driving it normally with regular street tires should not be a problem.
Beat on it constantly, and it will eventually break.
Put slicks on it and race it and it will break even faster.
Old Mar 10, 2006 | 03:24 PM
playa7970's Avatar
cool so what fuel pump would ya recom
Old Mar 10, 2006 | 03:54 PM
TraceZ's Avatar
I've never replaced one myself, sorry. I've heard good things about the Walbro 255 pump. When I replace mine it will likely be that one.
Old Mar 10, 2006 | 05:54 PM
JustNO's Avatar
The popular choice is 135-FLT1-FPK2 249$ at Thunder Racing
http://www.thunderracing.com/catalog...vid=4&pcid=166
Old Mar 10, 2006 | 06:18 PM
FastZinTennessee's Avatar
I bought the 135-FLT1-FPA from-
It's $160 for the pump and the pieces you need to mount that aftermarket pump in the stock bucket assembly in the tank. I felt like I didn't need to spend the extra $90 on the wiring for it.
I did have to grind on the stock bucket a little to get the pump to fit in there, and was kind of aiming in the dark because the manufacturer doesn't put any instructions in the kit. You can email www.racetronix.com and get the installation instructions though.
Old Mar 10, 2006 | 07:01 PM
playa7970's Avatar
Cool Re: Forged 383 Le2 Setup
thanks for the advice good looking out
Old Mar 10, 2006 | 07:40 PM
TQdrivenws6's Avatar
I went with the full PnP kit from Racetronix. Also, what about ARP main studs? The rest looks pretty good, but don't expect that '60E to last forever.
Old Mar 10, 2006 | 08:07 PM
playa7970's Avatar
thanks for the info i just want it to hold up for about a month and a half till i get my bank account up there again lol should be ok right?oh and yes i forgot to mention the arp main studs and lt4 km my bad....
DirtyDaveW
Dec 1, 2016 05:37 PM
drptop70ss
Mar 26, 2015 01:50 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
97 RedSS
Jun 10, 2003 07:58 PM
