Ford SVO injectors - Problems?
Old Aug 17, 2004 | 02:25 PM
TobyZ28's Avatar
http://www.ls1tech.com/forums/showthread.php?t=141719
Does this apply to LT1's at all? I know a lot of people run the SVO's but would anyone here not recommend running them because they dont fit quite right in the LT1 as well? I've heard a bit here and there of this but am hoping someone is a bit more knowledgeable about the SVO vs Stock injectors.
I do know i'll have to reprogram the computer a slight bit to compensate for them running at a lower psi.
Theyre SOOO much cheaper than the stock sets I see!
Old Aug 17, 2004 | 02:38 PM
TobyZ28's Avatar
Re: Ford SVO injectors - Problems?
http://www.slponline.com/view_produc...RTNUMBER=23051
Also how reliable/unreliable are these injectors? Theyre not flow tested or anything... But if I were to get a set that were flowed to +-3% its like 300$+! Is the flow testing really that critical?
Old Aug 17, 2004 | 02:42 PM
turbo_Z's Avatar
They dont fit quite as well as stockers for the simple fact you cant put the stock clips back on that holds the injector to the fuel rail... they seemed to be identical size-wise and I run mine w/o problems.
Old Aug 17, 2004 | 02:48 PM
TobyZ28's Avatar
Will I need to get new clips? Or is it "ok" to run them not clipped to the rail...
Old Aug 17, 2004 | 02:52 PM
WS Sick's Avatar
I ran the 30 #ers on my 93 for 4 or 5 years with no clips, no problems, theyve been on my 97 for a year now no problems , no clips, no burnt pistons.
The reason the clips done work is not length , but the lack of a groove for the clip, the injectors are the exact same length as the stockers.
Old Aug 17, 2004 | 08:40 PM
96capricemgr's Avatar
I think the clips are more important for holding the injectors to the rail at the factory than they are in the car, with the rail bolted to the intake the injectors are not going anywhere. I have run without clips for over 50K over the last several years.
Old Aug 17, 2004 | 10:25 PM
Spinner's Avatar
They're physically alike to the LT1 injectors. LS1 injectors are shorter and narrower by a tad bit.
Like 96caprice, the clips are unneccary. I took mine off when the SVOs went on. They're bolted in place, clips are redundant
Old Aug 17, 2004 | 10:47 PM
BlackbirdWS6's Avatar
havent had a problem with mine, and i put the clips on just for the sake of it. I kno it doesnt matter since they wont be going anywhere but just did it anyway.
Old Aug 17, 2004 | 11:19 PM
TobyZ28's Avatar
Great, I think SVO's are the way to go for me
Any suggestions as to where to get them from? And as per my post about http://www.slponline.com/view_produc...RTNUMBER=23051 would these be sufficient? They 99$ because they have not been flow tested. Is flow testing them to within +-5 or 3% really that neccessary?
Old Aug 17, 2004 | 11:57 PM
RE AND CHERYL's Avatar
Those are LS1 injectors if I'm not mistaken. The LS1 runs higher fuel pressure so the flow rating will be lower when used in a LT1. Besides, 25lbs is basically stock.
Old Aug 18, 2004 | 06:29 AM
95RagtopTA's Avatar
Go to Corral.net--it's a Mustang forum and you can find used 30 SVO's there all the time. I ended up getting mine for $135 from there--only had 5,000 miles on them. Otherwise, if you want to buy them new try THIS place, they're the cheapest that I found.
Also, as far as them fitting, I just took a dremel to them and extended the ring around the injector, clips slid right on and it only took a few minutes to do them all.....
Old Aug 18, 2004 | 08:35 AM
WS Sick's Avatar
If you can't find a set of good used ones , new ones from Summit or Jegs are just a few $s over 200$, If I remember right after handling and all mine came to 231$, but that was a year ago. I bought my set on my 93 used for 120$
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
