flywheel bolts?
Old Jun 11, 2006 | 04:56 PM
96LT1TX's Avatar
flywheel bolts?
I am using the flywheel tq specs from http://www.bfranker.badz28.com/fbody/torquespecs.htm of 74 ft/lbs, are these the bolts that mount the flywheel to the crank's specs?
thanks again
Old Jun 11, 2006 | 10:36 PM
Polo-94Z28's Avatar
Re: flywheel bolts?
Yes, 74ftlbs is the spec for the flywheel to crankshaft bolts. 22ftlbs is for the pressure plate to flywheel bolts...
dont forget that loctite.
Old Jun 12, 2006 | 07:32 AM
wrd1972's Avatar
Re: flywheel bolts?
Does GM loctite their flywheel bolts?
I agree that this is a good idea but I have never done this and I have never had any flywheel bolts back out.
Old Jun 12, 2006 | 09:25 AM
OBE1 95Z28's Avatar
Re: flywheel bolts?
Loctite them, you don't want a flywheel bolt backing out
Your also going to need a friend to keep the crank from rotating when you torque down the bolts. I usually have a buddy use a breaker bar and socket on the crank pulley or hub.
Old Jun 12, 2006 | 09:28 AM
MyShibbyZ28's Avatar
Re: flywheel bolts?
GM does not use loctite on the bolts. I used loctite though when I replaced my flexplate just for reassurance. There is a flywheel wrench you can buy so the flywheel will not turn while you torque the bolts.
Old Jun 12, 2006 | 10:27 AM
speed_demon24's Avatar
Re: flywheel bolts?
If you have a friend you can have them hold the ballancer bolt so the flywheel bolts won't back out.
Old Jun 12, 2006 | 11:55 AM
Z28SORR's Avatar
Re: flywheel bolts?
Holding the crank and/or rotating the engine with the harmonic ballancer bolt is a very bad idea, as you can easily over torque this bolt.
Old Jun 12, 2006 | 01:11 PM
wrd1972's Avatar
Re: flywheel bolts?
I just use a piece of 2x4 to wedge between the flywheel teeth and the floor.
You can also just slip a phillips screwdriver through a pressure plate mounting hole which will easily grab something. Works every time.
Old Jun 12, 2006 | 02:21 PM
DrewHMS97SS's Avatar
Re: flywheel bolts?
while under the car I put presure on the bolts facing away from the center of the flywheel. This made it so the engine would not turn as I torqued the bolts.
Old Jun 12, 2006 | 02:40 PM
96speed's Avatar
Re: flywheel bolts?
ARP Flywheel bolts are a GREAT investment (10 bucks). The shallow headed hex head stockers make for a real pain. The ARP bolts have a taller head and are 12point .
Ryan
Old Jun 12, 2006 | 02:58 PM
OBE1 95Z28's Avatar
Re: flywheel bolts?
I'll need to double check the torque value, but my memory has it that the values were nearly identical.
Old Jun 14, 2006 | 12:04 PM
sweetride45's Avatar
Re: flywheel bolts?
I bought these, "113-200-2802" ARP bolts from Thunder when I was rebalancing the flywheel to the new assembly. Weird thing is, they didn't fit! Had to use the stockers...
BigWil
Mar 29, 2015 12:24 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
