Flywheel???
Old Aug 13, 2003 | 08:01 AM
twdz28's Avatar
Flywheel???
Is it ok to resuface the flywheel??? If so do you need to shim it??? Also the only reason im asking is it's not crack and its still smooth but their are some heat spots in it... What do you think???
Leave it alone, resurface it, or buy a new one???
Old Aug 13, 2003 | 09:08 AM
AxeGrinder30thZ's Avatar
Buy a better one.
Old Aug 13, 2003 | 09:15 AM
twdz28's Avatar
Originally posted by AxeGrinder30thZ
Buy a better one.
what is your idea of a better one???
Old Aug 13, 2003 | 09:23 AM
An aftermarket lightweight flywheel.
Old Aug 13, 2003 | 09:39 AM
twdz28's Avatar
i'd rather hear some pro's and con's about the one i have...
Old Aug 13, 2003 | 10:10 AM
PatriotTA's Avatar
Well, why do you want to resurface your flywheel? Are you changing clutches? If you are, I would highly reccommend you take it to an automotive machine shop and have it surfaced. You don't need to shim it, it doesn't change anything, because the platforms for the pressure plate bolts are surfaced as well, so everything stays relative. There's no real pros or cons to it, its just something you need to do when you swap clutches. I didn't feel it was worth the money to buy a new flywheel when I changed clutches recently. The only problem you can run into is if the flywheel becomes too thin (much like brake rotors). If this is the first or second time its been surfaced, you should be fine. I had mine resurfaced and checked for cracks for $30.
Old Aug 13, 2003 | 10:28 AM
twdz28's Avatar
thank you, thats what i wanted to know... i am changing the clutch out... i noticed their where heat markings on it, it doesnt have any cracks at all... this will be the first time it will be resurfaced...
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
