air cond and miss
Old May 22, 2007 | 06:47 PM
SkiBumDreams's Avatar
air cond and miss
it seems whenever i turn on the air (or front defog) i have a miss or stumble. I always notice this when cruising at a constant speed. If the control is off or in the other modes (besides air or defog) there is no issue. anyone ever seen this before?
Old May 22, 2007 | 07:20 PM
bingo's Avatar
That is probably the load the A/C compressor puts on the engine. Does it drop RPMs when this happens? The compressor is only engaged when A/C and defrost are used.
Old May 22, 2007 | 07:37 PM
yea i figure there will be some load and it does happen in a regular interval around every 15 or maybe 30 seconds, but i wouldnt think it would be quite so noticable.
Old May 22, 2007 | 08:20 PM
green.Z's Avatar
Definitely, the A/C compressor will cause the engine to seem like it is "missing out". It is fairly noticeable to me at idle, but I haven't noticed this at cruising. Maybe try taking your drive belt off and checking the compressor. Make sure the compressor pulley spins freely.
Noct
May 26, 2016 10:26 AM
HarleyZ28
Oct 5, 2015 06:23 AM
armedtrigger
Feb 24, 2015 08:30 PM
Fatdog2
Feb 13, 2015 08:19 PM
95chwagon
Jan 13, 2015 09:19 PM
