Fluidampr shim?
Old Mar 31, 2011 | 02:44 PM
LT1 POWR's Avatar
Fluidampr shim?
Fluidampr sent a keyed shim with the dampner, is that needed? I have a double row timing chain and a 24X sprocket and EFI connections timing cover. Do you just install the dampner until it mates flush with the timing cover?
Old Mar 31, 2011 | 05:28 PM
SnakeOiler's Avatar
Re: Fluidampr shim?
It is not needed for engines with the CPS (which yours should have). I believe the instructions tell you that.
Old Mar 31, 2011 | 10:12 PM
LT1 POWR's Avatar
Re: Fluidampr shim?
It didn't come with squat for directions. I'm now wondering if even without the shim, it'll stick out too far due to the 24x crank reluctor. EFI connection recommends a 96+ vortec balancer.
Old Apr 1, 2011 | 05:21 AM
MikeGyver's Avatar
Re: Fluidampr shim?
I think I had to run one on my '95 or else the fluidampr was really close to the optispork.
achipfef
May 5, 2015 10:20 AM
C Man
May 7, 2003 08:03 PM
Draco
Mar 18, 2003 06:20 PM
DubbyZ28Camaro
Feb 25, 2003 02:11 PM
Turbo6
Advanced Tech
Jan 4, 2003 09:29 PM
