Fluid dampers on EBay right now
Old Jun 25, 2004 | 09:39 AM
j071752's Avatar
While replacing my timing cover, I have the stock damper off, I can see some small cracks in the rubber but it appears sound. 97Z28 with 108,000 miles. I was wondering about a couple of fluid dampers on Ebay right now:
http://cgi.ebay.com/ebaymotors/ws/eB...907053889&rd=1
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Especially that last one at $95.
Anybody familiar with these? If it will reduce noice and engine vibration it seems like a good deal for the price to add some longtivity to the bottom side of the motor.
Opinions? Thanks!
Old Jun 25, 2004 | 10:00 AM
944v8inDFW's Avatar
Post Intresting you should ask
I went throught the same thinking you did when i discovered my damper was showing some sighs of wear. After all the negitives I read about cheap ones and even the hig end one. I bought a new one and hub from Sam Taylor. I think about $190. with $135 being the damper.
Long story but many years ago I bought a power pully set from a name brand supplier for a Chevy truck. A week or so after I noticed vibrations at certain rpms and given the age of the truck i let it go, chalked it up to old age of the truck. Anyway about 2 years later new motor new transmission, as in GM crate, same vibration. I was freaking out. Then realized only thing i reused was the power pully set. Put the new crate stockers on and it ran perfect! So the moral of the story is unless you got a high end motor dont use the low end balancer. Unless of course you get it and have it balanced with your crank and flywheel.
just my 2 pennies
Old Jun 25, 2004 | 11:39 AM
cliff929's Avatar
Those are both for the LT1 corvette. They are different from a camaro of firebird one. They wont work They are to long.
This one will fit though
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7905898898
Formula Steve
Sep 19, 2023 08:31 AM
blac94Z
Nov 4, 2015 01:59 PM
colts0455
Oct 4, 2015 09:47 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Daluchman1974
Sep 11, 2015 06:12 AM
