FLP longtubes and BMR trak-pak?
Anybody have any idea if this will work?? I have the boxed bmr subframe connectors and the trak pak.. the cross brace welded in where the old brace bolts up under the back seats, with the torque arm off of that not the trans?...any info is appreciated.
Later
Derek
Later
Derek
hsyr
I am running the trak pak and along with lca's and lca relocation brackets. My car is lowered with eibach prokit, and the crossbrace bottoms out constantly where it dips for the exhaust. I go to the track a couple of times a year and it is hard to launch because it is lowered and the best 60' time i could get is 2.0. That is partially launching technique and skill.
If i had to do it over I would just get the adjustable torque arm that bolts in the stock location and the lca's and relocaiton brackets.
Derek
Derek
Originally posted by 97 CAIVIAROSS
AsianSensation
Thanks for the pic!!! Looks like it will work. Where did you get that pic? Anymore showing the car on the ground.. ground clearance etc...
Derek
AsianSensation
Derek
You might want to go to their website for more pictures.
tdigger9899
Sep 7, 2015 10:56 AM
